Harks11
Sep 15, 2020Aspirant
shed connection , blank sheet of paper
I have a shed 30 metres from the house. There is an ethernet cable between the two.There is an Internet connection to the house is maximum 60 meg. What is the ideal way to create a network with the o...
CrimpOn
Sep 15, 2020Guru - Experienced User
Harks11 wrote:I have a shed 30 metres from the house. There is an ethernet cable between the two.There is an Internet connection to the house is maximum 60 meg. What is the ideal way to create a network with the one SSID. What equipemnt should I use.
Some additional information would be useful. Do you have an existing WiFi system that you wish to expand? (Orbi, perhaps?)
60mb is an 'unusual' number for an ethernet connection.
If there is an existing Orbi WiFi system in the house, then the ideal solution is to place an Orbi satellite with ethernet capability in the shed.
That would be an RBS20, RBS40, RBS50, or RBS40V.
Harks11
On the 60meg that is what the RAX80 says on speed test. The connection is a 50meh fixed wireless. I made mention to show its not super fast fibre
