Retired_Member
Feb 05, 2020Shotty Wifi and Satellite Will Not Stay Connected
II recently just moved from a single level place (1000 sq. ft.) to a split level home(1500 sq. ft.) and never had the problems I am currently dealing with. Before I moved, I only had an issue with an...
Feb 05, 2020Guru - Experienced User
How far apart are the router and satellite? 30 ft minimum is recommended.
Have you tried enabling/disabling: mi-mimo, beamforming?
What modem are you using?
Is it only the satellite having this issue? What I mean is only the satellite dropping wifi connections? Does the main router have the same issue?
- Retired_MemberFeb 05, 2020
1) ~15ft - One is on the first level of the house and the other is directly above it on the second level. I want to hardwire my computer to the satellite if possible.
2) I have not yet. I will try that next.
3) I am using an Arris SB6190
4) I will disconnect the satellite completely and get back to you. What should I do if the satellite is the issue? What should I do if it's both?
