Retired_Member
Feb 05, 2020Shotty Wifi and Satellite Will Not Stay Connected
II recently just moved from a single level place (1000 sq. ft.) to a split level home(1500 sq. ft.) and never had the problems I am currently dealing with. Before I moved, I only had an issue with an...
Retired_Member
Feb 05, 2020I will combine the SSIDs and try again. As far as the pairing goes, I am always getting the blue light when they sync.
Feb 05, 2020Guru - Experienced User
You may see a config sync message in the status about the RBS on the RBRs UI.
Factory reset the system and setup from scratch. Try the following as well:
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
