Tempo36
Nov 07, 2019Aspirant
Should I change to AP mode or Bridge?
Today I got new Centurylink Fiber set up at a new home and they installed their own Actiontek C3000 router. I had read up on the topic and was all ready to have to set up the Orbi in AP mode or to tr...
Nov 07, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Depending if there router can be removed or not depend upon want you could do with the RBR. Ask the ISP of there router can be replaced by the RBR. If not, then you have options from above to review...
