Ken2122
Oct 14, 2019Tutor
Should I correct the date/time on my router?
I just bought a new router. I am troubleshooting an intermittent problem with WiFi disconnects. I noticed under the Advanced/Administration/Log section, the date is correct but the time is incorrect ...
- Oct 14, 2019
If you have not made any settings that depend on knowing the time, then there is no urgency to make the time exact.
However, changing the time will not cause any problem and I prefer to have the time be correct.
CrimpOn
Oct 14, 2019Guru - Experienced User
- Ken2122Oct 15, 2019Tutor
Thanks. I corrected the timezone, all is well.
