Deihmos
Feb 03, 2019Guide
Should I enable daisy chain?
I have the RBK50 and 1 satelite. Should I enable daisy chain? From everything I have seen it is only used if you have 2 satelites. I am experiencing some issues where the router slows down and has to...
Placesandspaces
Feb 03, 2019Apprentice
Also Netgear has a WiFi analyzer app you can use to see what channels are best to use in your neighborhood (I think it is only for Android devices though but very good). I had to do a reset through my ISP so it could clear up any connection issues along with rebooting my own modem, router, and Orbi system. Start with your ISP first to make sure no issues on there end then start checking your own set up until you can pinpoint the issue(s). Also did you customize your Orbi during the set up or did you use the smart wizard to do it for you?
biodieselman
Feb 04, 2019Aspirant
I can't find the Netgear wifi Analyzer app for IOS. Can you help me out please?
I have the ORBI app but that does not analyze surrounding WIFI networks to look at interference...
- FURRYe38Feb 04, 2019Guru - Experienced User
It's NetGear WiFi Analytics on my Galaxy Tab S2.
- ekhalilFeb 04, 2019MasterA good wifi analyser for IOS devices is in Apple Airport Utility, a free Apple app.
- PlacesandspacesFeb 04, 2019ApprenticeI think it is actually called Netgear Analytics. You can access it through the Google Playstore on Android devices. I don’t think it is available through IOS.
It appears as WiFi Analytics on my Samsung with the NG "N" in the app icon.
Placesandspaces wrote:
I think it is actually called Netgear Analytics. You can access it through the Google Playstore on Android devices. I don’t think it is available through IOS.- PlacesandspacesFeb 04, 2019ApprenticeThat is the correct one. Very good app to help determine what the best WiFi channel is in your area.
- FURRYe38Feb 05, 2019Guru - Experienced User
Let us know if the app helps you with your channelization.
