samlopez
Sep 15, 2019Follower
Should we expect a wifi 6 orbi cable modem?
Hello all!! Just about to acquire Orbi to replace my outdated mesh system... but as it always happens, when I’m about to get something, there are news about a updated version coming up... (WIFI 6...
Sep 16, 2019Guru - Experienced User
A. I probably wouldn't get the integrated version (modem and router). I'd buy a modem seperate that way you control the routers firmware and you can update as needed for cheaper.
B. Not sure how long you want to wait. I haven't used the new orbi but I've used a few other AX (wifi 6 devices) and the firmware is still a bit beta running (buggy). Maybe in 6 months when they've had time to get most of the major issues ironed out, then I'd recommend them.
I have the current version of orbi RBK53 and I've used the Arris mesh ax11000 and I went back to orbi because it was just as fast, firmware was more stable, and it just worked all the time. There's always going to be something new coming out. Figure out exactly what you're needing and buy something that'll handle a bit more than that for cushion. Again, if you need it now and like stability, I'd steer away from wireless AX. If you're planning on waiting then you might be ok.
