Pmancuso
Jun 14, 2020Follower
show 2.4gz and 5gz
how do i get the 2.4gz and 5gz to show as a choice? i need to connect a device to 2.4 and it doesnt show
CrimpOn
Jun 14, 2020Guru - Experienced User
The short answer is, "yes, it does show." If a device has only a 2.4G radio chip, it can see ONLY 2.4G WiFi channels. If it "sees" the Orbi WiFi name (SSID), then what it sees is 2.4G.
