packgreen49
Dec 15, 2019Aspirant
Signal Strength
On the wireless setting. Why am I getting a Stronger setting when I am 30 feet from the router than right by the router. Something like 100 at the router and 300 about 30 feet from the outer? My s...
Dec 15, 2019Guru - Experienced User
Signal propagation depending upon buiding materials, surroundings and noise and interference will be a factor. Usually strong signals near the source can be over powering to connected devices. Getting distance will cause the signal to improve for the device. Most distances starting are around 6 feet from the RBR. 30 feet seems to be the sweet spot for RBR and RBS wifi over lap connections so RBS at 30 feet is a good starting point and beyond. Depending upon building materials of course.
- packgreen49Dec 15, 2019Aspirant
Even my Ethernet connection was low (100).
- FURRYe38Dec 15, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Is your ethernet adapter connecting at 100Mbps or 1000Mbps to the back of the RBR?
Firmware: V2.3.5.6
The Modem is supplied by WOW cable. Its ARRIS SB6183.
Small townhouse maybe 2,000sq.ft.
I am assuming its operating has a router.
You gave me a checklist of items to check. I will go through each of them. I would assume everthing is auto.
I have neighbors of each side of me.
Ron
