packgreen49
Dec 15, 2019Aspirant
Signal Strength
On the wireless setting. Why am I getting a Stronger setting when I am 30 feet from the router than right by the router. Something like 100 at the router and 300 about 30 feet from the outer? My s...
packgreen49
Even my Ethernet connection was low (100).
Dec 15, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Is your ethernet adapter connecting at 100Mbps or 1000Mbps to the back of the RBR?
- packgreen49Dec 15, 2019Aspirant
Firmware: V2.3.5.6
The Modem is supplied by WOW cable. Its ARRIS SB6183.
Small townhouse maybe 2,000sq.ft.
I am assuming its operating has a router.
You gave me a checklist of items to check. I will go through each of them. I would assume everthing is auto.
I have neighbors of each side of me.
Ron
