packgreen49
Dec 15, 2019Aspirant
Signal Strength
On the wireless setting. Why am I getting a Stronger setting when I am 30 feet from the router than right by the router. Something like 100 at the router and 300 about 30 feet from the outer? My s...
Dec 15, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Is your ethernet adapter connecting at 100Mbps or 1000Mbps to the back of the RBR?
packgreen49
Firmware: V2.3.5.6
The Modem is supplied by WOW cable. Its ARRIS SB6183.
Small townhouse maybe 2,000sq.ft.
I am assuming its operating has a router.
You gave me a checklist of items to check. I will go through each of them. I would assume everthing is auto.
I have neighbors of each side of me.
Ron
