MMagic's avatar
MMagic
Follower
May 22, 2018
Singtel TV with Netgear Orbi
Does anyone know if it is possible to use the Orbi wifi solution to replace the Singtel provided router and still allow internet (through fibre sconnection) and Mio TV to work in Singapore or does the Orbi router have to sit on top of the Singtel provided router?
I know that you can configure Linksys routers (with pre-configured drop down options) to do this but I wasn't sure if this is possible to do with the Orbi and if it was, how you could accomplish this with detailed steps?
1 Reply
  • FURRYe38's avatar
    Is Singtel your ISP?
    What is the Mfr and model# of the ISP modem and router your using?
