Yeo85
Mar 21, 2019Follower
Singtel TV with Netgear Orbi
Hi,
Need some help with singtel TV connect to ORBI router RBK 40.
I have done the necessary VLAN as attached. Unable to connect my Singtel TV box.
Try connect router port 3 to singtel TV box but fail.
Router firmware version 2.2.1.210
Need your assist..
Need your assist..
1 Reply
Is the Orbi system operating in Router or AP mode?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Is the TV box required to be connecte to the ISP modem rather then the Orbi?
Yeo85 wrote:
Hi,
Need your assist..
