mangyj's avatar
mangyj
SiriusXM Blocked On RBR50
I installed my Orbi RBR50 (indicates "RBK50" on the box though) over a week ago.  It initially worked great.  No problems whatsoever.   Suddenly today I can no longer stream SiriusXM over the Orbi ...
  • CrimpOn's avatar
    CrimpOn
    May 19, 2020
    Jetdrive wrote:
    I remember a post about this very same issue in the past but can't remember the resolution.
    It's possible it was doing a factory reset after turning off Armor. Might be worth a try.
    Doing a factory reset will definitely eliminate Armor, because one of the first things that comes up on the web interface during the configuration is a screen recommending that Armor be installed.  I always say (politely), "Not a chance in hell."
    I just did a search on the Armor community forum for "SiriusXM" and got zero hits.  One would think if Armor does not play well with SiriusXM, somebody would have mentioned that in the Armor forum.
    Have you tried changing to a different DNS server, such as Google 8.8.8.8 or Cloudflare 1.1.1.1 ?
