mangyj
May 19, 2020Aspirant
SiriusXM Blocked On RBR50
I installed my Orbi RBR50 (indicates "RBK50" on the box though) over a week ago. It initially worked great. No problems whatsoever. Suddenly today I can no longer stream SiriusXM over the Orbi ...
- May 19, 2020
Jetdrive wrote:I remember a post about this very same issue in the past but can't remember the resolution.
It's possible it was doing a factory reset after turning off Armor. Might be worth a try.
Doing a factory reset will definitely eliminate Armor, because one of the first things that comes up on the web interface during the configuration is a screen recommending that Armor be installed. I always say (politely), "Not a chance in hell."
I just did a search on the Armor community forum for "SiriusXM" and got zero hits. One would think if Armor does not play well with SiriusXM, somebody would have mentioned that in the Armor forum.
Have you tried changing to a different DNS server, such as Google 8.8.8.8 or Cloudflare 1.1.1.1 ?
CrimpOn
May 19, 2020Guru - Experienced User
Jetdrive
May 19, 2020Luminary
You might want to check the status of your XM subscription. Also give it a try on cellular data to see if it really is a problem with the Orbi.
