lensman
Aug 01, 2021Tutor
Site to Site VPN
Greetings fellow Orbi owners. I have two houses, both with Orbis. I would very much like to stand up a site-to-site VPN between the two. Everything I see though indicates support only for VPN c...
CrimpOn
Aug 06, 2021Guru - Experienced User
Having two routers on hand definitely reduced the cost. And, using OpenWRT routers removes the need for two ISP connections.
Having never done anything like this myself, my thought is the following:
- The two LAN's must have different IP subnets. For example:
* The near LAN could be 192.168.1.x and
* The far LAN could be 192.168.2.x - Connect the OpenWRT router WAN port to the Orbi LAN side (on each end, near and far).
- Connect one OpenWRT LAN port to the Orbi LAN side.
- (I would allocate specific IP's to these ports inthe Orbi LAN setup.)
- Nothing else connected to the OpenWRT routers.
- The ports needed for OpenWRT will need to be forwarded through the Orbi to the OpenWRT routers on each end.
I believe these are UDP 1193 and 1194: https://openvpn.net/vpn-server-resources/advanced-option-settings-on-the-command-line/
One is for tun and one for tap. - Disable WiFi on the OpenWRT routers (or not if there is some reason to have competing WiFi's)
- Define the LAN to LAN VPN from near to far (and test it somehow?)
- On Near side Orbi, create a static route for the far side IP subnet pointing to the OpenWRT LAN port.
- On Far side Orbi, create a static router for the near side IP subnet pointint to the OpenWRT LAN port.
- Devices on each end will behave as normal.
* Traffic to devices on the local LAN till stay within the local Orbi LAN
* Traffic to the internet will go out the Orbi WAN port as normal.
* Traffic to the other site will be directed to the OpenWRT router which sends it though a tunnel to the far end OpenWRT router, which puts it on the far LAN.
At this point, it might be worth considering what type of VPN connection is desired, i.e. tun vs. tap. This is based on:
- What the intended use is and
- How much LAN traffic do you want "leaking" from one site to the other. (broadcasts, ARP's, etc.)
If you actually give this a try, please return and update the post with the results.
lensman
Aug 06, 2021Tutor
Will do. Still weighing pros and cons. I was thinking the routes would be defined on the OpenWRT router rather than the Orbi though no? Everything go from Orbi to OpenWRT and then route based on destination. If 192.168.[1,2 based on which side].0/24 - VPN, anything else, ISP. My concern there is performance since the OpenWRT would be a passthrough and older hardware might not be as quick (500mbit links). Still just a thought experiment for now.
- CrimpOnAug 06, 2021Guru - Experienced User
My only concern with that is the incomming traffic, unless the Orbi is put into Access Point (AP) mode. To the OpenWRT router, it knows where it's own LAN is and the Orbi is one of the devices on that LAN. It might need another static route to say that traffic to the Orbi LAN goes to the Orbi WAN port. AP mode would mean there is no "Orbi LAN", only the OpenWRT LAN.
This is Waaaay over my head. Good Luck.
- lensmanAug 06, 2021Tutor
I'm stretching here too but fortunately have an entire team of network engineers working for me so you know I'll be hashing it out with them :-)
As I was drawing this out just now, I realized it was leading to having the Orbis in AP mode. Not happy about that.
The end goal is to share the Drobo files in one location with the other location. That and RDP to a system in NJ when in FL. Might need to look at a plan B.
Drobo? RDP into a desktop screams out "OpenVPN on the Orbi". With a laptop containing the VPN config files for both NJ and FL, the laptop can reach either LAN from anywhere.
I had wandered off into the thoughts of making daily database backups from site to site, send things to printers, streaming videos (probably not a business need).
