Celeri
Apr 30, 2018Star
Sites inaccessible because of Circle since last firmware
Since firmware 2.1.4.10 some sites are inaccessible (eg blogspot.com, icloud.com) with Circle enabled, even with no filter level. By disabling Circle, everything works perfectly. Obviously, with th...
Yamamoto
Apr 30, 2018Star
I have experienced the same exact problem.
I have reset circle and set it back up as a new circle account and the same problem exists.
Clearly a firmware problem, because until 2.1.4.10, circle ran great, now it it having problems.
Until netgear fixes these problems, future mesh router consumers should absolutely look elseware. Too many hours of headaches, with no response from netgear.
Shameful
- DarrenMMay 01, 2018Sr. NETGEAR Moderator
I have tested this with my system and I am not seeing the same issue can you give me some more examples of websites that do not work with circle enabled.
DarrenM
- YamamotoMay 01, 2018StarCars.com
Do a filtered search
ebaumsworld.com
Google speed test (2 separate words) then click the blue box to run speed test. Do not click link to Speedtest.net- DarrenMMay 01, 2018Sr. NETGEAR Moderator
I still am not seeing the issue I have applied all the default filters maybe try to change your DNS in your orbi Internet settings to googles DNS and then try with circle enabled.
DarrenM
- CeleriMay 01, 2018Star
On my side with any filter level activated : ***.blogspot.com, icloud smtp server, some games like Score Match on iOS...
Cicle disable, everything is ok.
