Celeri
Apr 30, 2018Star
Sites inaccessible because of Circle since last firmware
Since firmware 2.1.4.10 some sites are inaccessible (eg blogspot.com, icloud.com) with Circle enabled, even with no filter level. By disabling Circle, everything works perfectly. Obviously, with th...
kippers
May 02, 2018Guide
Yes, same here. I responded earlier with some details but my response has been removed from this thread (is Big Brother watching?)
With Circle enabled, numerous sites will not load and say "resolving host". Disable Circle and all is fine.
- CeleriMay 02, 2018Star
So i'm not alone.
Another website blocked by Circle : orbilogin.com !!
- kippersMay 02, 2018Guide
ah yes, the irony of "orbilogin.com" not resolving......
If you have not tried this already, then try accessing the router using the IP address. On your local network it should be: http://192.168.1.1
- YamamotoMay 02, 2018StarKippers
Did you delete your post? Or did netgear delete it?
