Celeri
Apr 30, 2018Star
Sites inaccessible because of Circle since last firmware
Since firmware 2.1.4.10 some sites are inaccessible (eg blogspot.com, icloud.com) with Circle enabled, even with no filter level. By disabling Circle, everything works perfectly. Obviously, with th...
mimicvii
May 01, 2018Tutor
Exact same problem with Circle after the 2.1.4.10 firmware. Some websites (not all) get stuck on "resolving host" before eventually loading a page with only text (as if the css isn't loading). For me, it did this with speedtest.net and I'm endlessly "connecting" to channels within a Discord server. Setting a device to "unmanaged" or disabling Circle all together immediately resolves the issue.
DarrenM
May 02, 2018Sr. NETGEAR Moderator
I have escalated this issue to engineering and will let you know what I find out about this issue.
DarrenM
- CeleriMay 02, 2018Star
Thanxs DarrenM !
I disabled Circle... for the moment
- DarrenMMay 02, 2018Sr. NETGEAR Moderator
Our engineers are looking into this if someone could help that is having this issue please send me a PM with your Orbi serial number, when you first started seeing this issue and your debug log where you can get to by going to https://192.168.1.1/debug.htm start a capture then enable circle try to visit a blocked site and then stop the capture and send me that file.
Thanks
DarrenM
- mimicviiMay 02, 2018Tutor
Well, after re-enabling circle, it appears to be working now.Spoke too soon, it eventually started doing the same thing again. Will send logs.
