td3201
Jun 05, 2018Aspirant
sizing new orbi system
Hello,
I'm looking at buying the Orbi system for my home. I have two levels, basement, and a backyard patio/pool area that I'd like covered. All in, it's about 4500 ft2. I can put my cable mode...
- Jun 05, 2018
Similar to mine. two story house with basement under mine.
Yes, keep router on same level or router on main level and satellite on 2nd level. I have my router up on 2nd level at one end of my house and 1 satellite at the opposite end on main level. My ISP modem is place up on 2nd level where my modem and all my networking equipment is.
td3201
It's a big rectangle. So you're saying keep both satelite and router on same level?
Jun 05, 2018Guru - Experienced User
- td3201Jun 05, 2018Aspirant
Ok cool but I should be able to get this done with just a router and a satelite you think? And sorry for the dumb question but just confirming. The satelite bridges into the network wirelessly without an ethernet drop, correct?
- FURRYe38Jun 05, 2018Guru - Experienced User
Yes should be good with just one satellite to start.
Yes the satellite wirelessly bridges to the main router while also handling AP mode connections.
- td3201Jun 06, 2018Aspirant
I bought what you recommended and will try it out! I'm hoping the app has coverage strenghth and mapping capabilities. I could see having to put an outside AP as well but will cross that bridge later.
Thanks
