Bigleemo
Mar 12, 2019Aspirant
Sky + HD box crashes Orbi RBR40
My Orbi RBR40 crashes / reboots everytime I try to download a tv program to my Sky + HD box. It doesn’t matter if the Sky box is connected via cable or wireless the Orbi still reboots. My Orbi is run...
Mar 13, 2019Guru - Experienced User
Bigleemo wrote:
My Orbi RBR40 crashes / reboots everytime I try to download a tv program to my Sky + HD box. It doesn’t matter if the Sky box is connected via cable or wireless the Orbi still reboots. My Orbi is running firmware 2.2.1.210. Please help.
Bigleemo
Mar 13, 2019Aspirant
Internet router connected to Netgear Orbi is standard router supplied by plusnet. Manufacturer is Sagemcom, couldn’t find a model number.
- FURRYe38Mar 13, 2019Guru - Experienced User
Need to check to see if the ISP Modem has a built in router. That why we ask for the model#. If it does have a built in router already...
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option#2 if you have access the modems web page. If not, then try option #3.
- plemansMar 13, 2019Guru - Experienced User
Modem Combo Units:
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopDang you typed that fast. Was in process of asking about if its combo device but couldn't type fast enough!
Copy and paste is fast too. :smileyvery-happy:
plemans wrote:
Modem Combo Units:
