Bigleemo
Mar 12, 2019Aspirant
Sky + HD box crashes Orbi RBR40
My Orbi RBR40 crashes / reboots everytime I try to download a tv program to my Sky + HD box. It doesn’t matter if the Sky box is connected via cable or wireless the Orbi still reboots. My Orbi is run...
Mar 13, 2019Guru - Experienced User
FURRYe38 wrote:
Need to check to see if the ISP Modem has a built in router. That why we ask for the model#. If it does have a built in router already...
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Dang you typed that fast. Was in process of asking about if its combo device but couldn't type fast enough!
Copy and paste is fast too. :smileyvery-happy:
plemans wrote:
Modem Combo Units:
