Neel1994
Aug 24, 2018Tutor
Sky Q and orbi
Hi chaps. So I recently purchased an orbi and everything is running great! Apart from my damn sky Q!! The main box keeps disconnecting from the Orbi and I’ll get an X next to the network settin...
Aug 30, 2018Guru - Experienced User
I presume there maybe a wifi issue at the Sky Q device.
I would contact the Mfr and ask for some information regarding it. Check to see if the wifi drivers on it are up to date...
Try setting the power level on the routers wifi from 100% to 75 or 50%...
- Neel1994Aug 30, 2018TutorI will try lowering the power as you’ve said.
Does this only reduce the power of WiFi emitting on the router alone? Or does it effect the power of the satellites as well?- FURRYe38Aug 30, 2018Guru - Experienced User
I think it's only just the router...Let us know how it goes...
