LeBullet
Jun 03, 2019Apprentice
Sky Q download and connection dropping (solved)
Hi All, so, If you're a UK/Europe user and Orbi user, like me (last 2 years) you've probably had periods where Orbi has worked well, and periods where it has worked terribly poorly, to the point...
Jun 03, 2019Guru - Experienced User
Orbi does not support separation of SSIDs. If NG hasn't put this in then by now, you can presume NG won't be putting it in. Maybe in next Orbi AX system, however NG has only supported the disabling of either radio SSID temporarily. Chipset Mfr and NG implemented single SSID on there system and for the most part it does work. Most of the issues with Smart Connect are with the connected clients and there software and how they handle Smart Connect. Most of the problems are with these Mfrs and how they work with Smart Connect. Change needs to start there.
