jdbauer6
Oct 22, 2017Aspirant
Slow download = Fast Upload
Hi - using SpeedTest, I continually get around 40-60Mbps download vs. 150+Mbps upload. I am on the latest firmware, and am on the 5G network on either the satellite or router - same speeds. Any ...
jdbauer6
..and one other thing - I hardwired to the FIOS router, and I get 150/150 - so that's not the issue.
- DarrenMOct 24, 2017Sr. NETGEAR Moderator
Have you enabled beamforming or mumimo? also have you tried to re position your satellite?
DarrenM
- jdbauer6Oct 24, 2017Aspirant
Yes - I have tried with both of those settings on and off with little difference. I have not moved the satellite around, as I get fast performance on upload, so that’s likely not the issue?
- DarrenMOct 25, 2017Sr. NETGEAR Moderator
Do you have orbi set up as a AP or in router mode? if in router mode do you have your FiOS router bridged?
DarrenM
