jdbauer6
Oct 22, 2017Aspirant
Slow download = Fast Upload
Hi - using SpeedTest, I continually get around 40-60Mbps download vs. 150+Mbps upload. I am on the latest firmware, and am on the 5G network on either the satellite or router - same speeds. Any ...
DarrenM
Oct 24, 2017Sr. NETGEAR Moderator
Have you enabled beamforming or mumimo? also have you tried to re position your satellite?
DarrenM
jdbauer6
Oct 24, 2017Aspirant
Yes - I have tried with both of those settings on and off with little difference. I have not moved the satellite around, as I get fast performance on upload, so that’s likely not the issue?
- DarrenMOct 25, 2017Sr. NETGEAR Moderator
Do you have orbi set up as a AP or in router mode? if in router mode do you have your FiOS router bridged?
DarrenM
