bforbes70
Feb 07, 2020Aspirant
Slow Download for Excel Workbooks
I have a a Netgear Orbi RBR50 setup at home. Connection is great and all speed testing comes back around 400mbps. Streaming movies, tv, etc. there are no issues and internet speed on my computer i...
Feb 07, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- bforbes70Feb 17, 2020Aspirant
Current Firmware is V2.3.5.30
The Modem is Ubee E31U2V1
The house is 3000 square feet. I have the router in the basement with the modem and satelites on floors 1 and 2. No other devices have any connection issues other than the laptop when it comes to opening larger Excel workbooks.
The 2.4 Ghz was on auto and I have tried with 1, 6, and 11, there doesn't seem to be any change. I live on a residential street and it seems like I have 2-3 neighbors at any given time whose WiFi appears available to me.
I can try the other suggestions later today. I'm pretty green with all of this so I appreciate the help.
- FURRYe38Feb 17, 2020Guru - Experienced User
Does wired connection exhibit the same problem?
bforbes70 wrote:Current Firmware is V2.3.5.30
