Bosie
Apr 09, 2020Aspirant
Slow Download Speed with RBR20
MBpsWould love some help from the community! I have upto 900 MBps download speed from my modem (confirmed with wired connection). But when I connect it to my Orbi router and do a wireless speedte...
Bosie
Apr 10, 2020Aspirant
Thanks for the tip. I checked the speedtest in the app and found that the download speed is 403.48 Mbps which is faster than my previous test. However, it's still more than 1/2 the speed that I'm getting with a wired connection to my modem. I recognize that I should expect slower speeds with WiFi, but should the degradation be so significant?
ekhalil
Apr 10, 2020Master
What modem do you have? What is the make and the model please?
- BosieApr 12, 2020Aspirant
I have the Hitron E31T2V1 cable modem which is provided by my internet provider Spectrum. The technician was just here a few days back and was getting 900 mbps when he connected directly to the modem.
Also...I just reset back to factory settings and restarted my router. Still getting speeds at about 425 mbps.
- ekhalilApr 12, 2020Master
Bosie wrote:I have the Hitron E31T2V1 cable modem which is provided by my internet provider Spectrum. .......
This modem is also a router. Although that this should not affect the speed, but if you have Orbi in Router Mode then I think that you'll have many issues.
It seems that this router can't be bridged according to this manual. So I suggest setting Orbi in AP Mode if it's not already in that mode.
