bigfellanz
Jul 19, 2017Guide
Slow downloads due to high CPU load with V1.12.0.18 firmware
My internet access is 1000/100, and requires VLAN tagging to connect. This has been working very well with the Orbi for the last couple of months. Since upgrading to V1.12.0.18, my download speed...
scornwell
Jul 20, 2017Apprentice
Perfect for you perhaps, but clearly not for a significant number of others. The firmware is a long way from perfect.
Maybe VLAN tagging is the differentiator?
bigfellanz
Jul 20, 2017Guide
I might try putting another router in front of the Orbi, disable the VLAN tagging on the Orbi, and see if there is a difference in CPU usage.
- scornwellJul 20, 2017Apprentice
bigfellanz wrote:
Maybe VLAN tagging is the differentiator?I might try putting another router in front of the Orbi, disable the VLAN tagging on the Orbi, and see if there is a difference in CPU usage.
Good call. Let me know how you get on.
- DarrenMJul 20, 2017Sr. NETGEAR Moderator
Hello everyone
For anyone having the vlan tagging issue please send me a PM with your name, email, and phone number our support team wants to work with you on the issue.
Thanks
DarrenM
- kohlc69Jul 23, 2017Guide
Since the V1.12.0.18 firmware update. My download speed is appalling and operating at much lower speed before it get update. Before i am getting 200-300mbps but now i only 30-50mbps. Also I am on VLAN tagging due to requirement from service provider. Please let me know when a new firmware will fix these issues????
- kohlc69Jul 24, 2017Guide
Any finding or update on this?
DarrenM wrote:Hello everyone
Thanks
DarrenM
Thanks
DarrenM
- kohlc69Jul 26, 2017Guide
Any reply on this?
- scornwellJul 26, 2017ApprenticeRead the post by Darren above.
