kevincc
Nov 14, 2020Guide
Slow ethernet and wifi satellite speeds
 My devices that use an RBS20 satellite are very slow.  The speeds are roughly 30-50mbps. Doesn't matter if it is a wifi connection to the satellite or a wired ethernet connection to the satellite.  T...
kevincc
Dec 30, 2020Guide
I'll try again since there is no way to get actual support from Netgear. I have an RBS20 satellite about 1 foot away from my Orbi modem/router. I have a laptop plugged into an ethernet port on the RBS20. The download speed is 48Mbps. If I connect directly to the modem/router, the download speed is 240Mbps. Why is the wired connection to the RBS20 so slow? Anything I can try to improve this?
