kevincc
Nov 14, 2020Guide
Slow ethernet and wifi satellite speeds
My devices that use an RBS20 satellite are very slow. The speeds are roughly 30-50mbps. Doesn't matter if it is a wifi connection to the satellite or a wired ethernet connection to the satellite. T...
kevincc
Dec 30, 2020Guide
Sounds good. Thanks for your help.
Dec 30, 2020Guru - Experienced User
Ok, after FINALLY getting my RBS20 to connect to the CBR40, Having my RBK50 online doesn't help so RBS kept getting confused. :smileyfrustrated:
So seems to be a speed problem for sure with a wired PC connected behind the RBS20 thats connected to the CBR40:
I did a wire test thru the CBR to be sure wired is ok:
Connection rate is good and seems to be working:
CBR40 is in a faux AP mode since I don't have it connected to my ISP cable line. DHCP server disabled and the CBR40 LAN port connected to my RBK50 network.
Beamforming, MIMO, FR and WMM are enabled on the CBR. Manual Channel 11 and 48 as my RBK50 is on 1 and 36. I even turned down the power output of the RBR50 to lesson the interference.
I would make contact with NG support and open a support ticket. This needs to be looked at.
- kevinccDec 30, 2020Guide
Thanks for the follow up and for confirming the issue. Looks like they only have paid support. I'll try to give them a call.
- FURRYe38Dec 30, 2020Guru - Experienced User
Try a forum moderator as well...
- renanmarquesMar 11, 2021Tutor
Any luck with this case? I'm having the exact same issue.
- kevinccMar 11, 2021Guide
Nope. I gave up on Netgear. Switched to TP-Link Deco and it is way better.
I have just resurfaced my old Linksys Velop, and it works like a charm. Will probably give up on Netgear as well, except I actually bought the Modem/Router combo, so, 400usd for a modem, to connect my Linksys Velop to... doesn't get any more frustrating than this.
Ha! I'm in the same boat. Still using the Orbi Modem/Router. Very frustrating.
- Blanca_OMar 17, 2021NETGEAR Employee Retired
Hi kevincc and renanmarques
I have sent you a message. Please check your inbox.
Blanca
Community Team - RougeKatApr 18, 2021AspirantHas this been resolved? I have the same issue and I've done EVERYTHING I can find on the forum with no luck.
- kevinccApr 18, 2021Guide
Nope
- FURRYe38Apr 22, 2021Guru - Experienced User
Has anyone attempted to revert back to older FW on the CBR or RBS or both to see if the speed performance returns?
- FURRYe38May 02, 2021Guru - Experienced User
FYI, I was curious where the problem appeared. Seems to be on 2.2.1.210 as I reverted my CBR40 an RBS20 back to v210 today. Factory reset both CBR and RBS. Still same 50Mbps on the down with a wired PC connected to the back of the RBS20.
I reverted back to v2.1.4.6 on the CBR40 and v2.1.4.16 on the RBS20. Powered OFF both units for 30 seconds then back ON.
Look what the results were:
Seems that something broke in FW after v2.1.4.x
- buckleyphotoOct 23, 2021Aspirant
Hi,
I also just ordered a used RBS20 satellight. Not that tech savy... Could you please list the steps I could take to roll back the firmware to get back those speeds?
- FURRYe38Oct 24, 2021Guru - Experienced User
Install first version of the RBS FW on the RBS first:
Then do same thing to the CBR40:
buckleyphoto wrote:
Hi,
- buckleyphotoOct 25, 2021Aspirant
Thankyou!
- FURRYe38Oct 25, 2021Guru - Experienced User
Let us know how it goes...
- FURRYe38Jan 26, 2022Guru - Experienced User
Did you downgrade the CBR FW or the RBS FW?
chill_114 wrote:
Blanca_O can you please help me out with this issue as well, I am running the CBR40 and three RBS20's. The issue lays at the satelites being very slow like 20-30 mbs on the current firware, when I down grade to 2.1.4.x it runs much better
