kevincc
Nov 14, 2020Guide
Slow ethernet and wifi satellite speeds
My devices that use an RBS20 satellite are very slow. The speeds are roughly 30-50mbps. Doesn't matter if it is a wifi connection to the satellite or a wired ethernet connection to the satellite. T...
kevincc
Mar 11, 2021Guide
Nope. I gave up on Netgear. Switched to TP-Link Deco and it is way better.
renanmarques
Mar 11, 2021Tutor
I have just resurfaced my old Linksys Velop, and it works like a charm. Will probably give up on Netgear as well, except I actually bought the Modem/Router combo, so, 400usd for a modem, to connect my Linksys Velop to... doesn't get any more frustrating than this.
- kevinccMar 11, 2021Guide
Ha! I'm in the same boat. Still using the Orbi Modem/Router. Very frustrating.
- Blanca_OMar 17, 2021NETGEAR Employee Retired
Hi kevincc and renanmarques
I have sent you a message. Please check your inbox.
Blanca
Community Team - RougeKatApr 18, 2021AspirantHas this been resolved? I have the same issue and I've done EVERYTHING I can find on the forum with no luck.
- kevinccApr 18, 2021Guide
Nope
- FURRYe38Apr 22, 2021Guru - Experienced User
Has anyone attempted to revert back to older FW on the CBR or RBS or both to see if the speed performance returns?
- FURRYe38May 02, 2021Guru - Experienced User
FYI, I was curious where the problem appeared. Seems to be on 2.2.1.210 as I reverted my CBR40 an RBS20 back to v210 today. Factory reset both CBR and RBS. Still same 50Mbps on the down with a wired PC connected to the back of the RBS20.
I reverted back to v2.1.4.6 on the CBR40 and v2.1.4.16 on the RBS20. Powered OFF both units for 30 seconds then back ON.
Look what the results were:
Seems that something broke in FW after v2.1.4.x
- buckleyphotoOct 23, 2021Aspirant
Hi,
I also just ordered a used RBS20 satellight. Not that tech savy... Could you please list the steps I could take to roll back the firmware to get back those speeds?
- FURRYe38Oct 24, 2021Guru - Experienced User
Install first version of the RBS FW on the RBS first:
Then do same thing to the CBR40:
buckleyphoto wrote:
Hi,
- buckleyphotoOct 25, 2021Aspirant
Thankyou!
- FURRYe38Oct 25, 2021Guru - Experienced User
Let us know how it goes...
- FURRYe38Jan 26, 2022Guru - Experienced User
Did you downgrade the CBR FW or the RBS FW?
chill_114 wrote:
Blanca_O can you please help me out with this issue as well, I am running the CBR40 and three RBS20's. The issue lays at the satelites being very slow like 20-30 mbs on the current firware, when I down grade to 2.1.4.x it runs much better
