kevincc
Nov 14, 2020Guide
Slow ethernet and wifi satellite speeds
My devices that use an RBS20 satellite are very slow. The speeds are roughly 30-50mbps. Doesn't matter if it is a wifi connection to the satellite or a wired ethernet connection to the satellite. T...
RougeKat
Apr 18, 2021Aspirant
Has this been resolved? I have the same issue and I've done EVERYTHING I can find on the forum with no luck.
kevincc
Apr 18, 2021Guide
Nope
- FURRYe38Apr 22, 2021Guru - Experienced User
Has anyone attempted to revert back to older FW on the CBR or RBS or both to see if the speed performance returns?
- FURRYe38May 02, 2021Guru - Experienced User
FYI, I was curious where the problem appeared. Seems to be on 2.2.1.210 as I reverted my CBR40 an RBS20 back to v210 today. Factory reset both CBR and RBS. Still same 50Mbps on the down with a wired PC connected to the back of the RBS20.
I reverted back to v2.1.4.6 on the CBR40 and v2.1.4.16 on the RBS20. Powered OFF both units for 30 seconds then back ON.
Look what the results were:
Seems that something broke in FW after v2.1.4.x
- buckleyphotoOct 23, 2021Aspirant
Hi,
I also just ordered a used RBS20 satellight. Not that tech savy... Could you please list the steps I could take to roll back the firmware to get back those speeds?
- FURRYe38Oct 24, 2021Guru - Experienced User
Install first version of the RBS FW on the RBS first:
Then do same thing to the CBR40:
buckleyphoto wrote:
Hi,
- buckleyphotoOct 25, 2021Aspirant
Thankyou!
- FURRYe38Oct 25, 2021Guru - Experienced User
Let us know how it goes...
