quintinmorris
Mar 28, 2020Aspirant
Slow ethernet performance on Orbi
Hello, I have xfinity 1 Gb service to the house and a xfinity xfi modem in bridge mode. My router is an orbi RBK50 with 2 satellites connected through ethernet for the backhaul. My workstation ...
- Mar 28, 2020
Thanks for the responses everyone! I tested the cables and the cable between the router and the switch was bad! All fixed and getting the same performance as the router on the ethernet!
SW_
Mar 28, 2020Prodigy
If your client is wired to Orbi LAN port, you should get ~900Mbps. If your Satellite backhaul is also wired, your wired client from Satellite should see similar LAN speed. For wireless backhaul, it varies between ~250-500Mbps for wireles clients or Satellite's wired clients. Check out this thread.
- quintinmorrisMar 28, 2020Aspirant
Thanks for your reply!
Reading through that thread I htink my situation is a little different as my backhaul is all wired and my switch plugs directly into the orbi router, not a satellite. its frustrating that the ethernet performance is 1/10th of the service speed. It doesn't make sense! I get 600 Mbps on wifi in some places. cabling is all Cat 6...
Q
- SW_Mar 28, 2020Prodigy
Sound like a problem with link negotiation between client/switch/Orbi LAN ports. It's likely that it's currently doing 100Mbps instead of 1000Mbps. Try this:
- Power cycle the switch connected to Orbi
- Power cycle the client
- Verify Orbi LAN port to make sure it's settled on 1000Mbps for the client on the switch
- Rerun the test (possibly with different cables)
