quintinmorris
Mar 28, 2020Aspirant
Slow ethernet performance on Orbi
Hello, I have xfinity 1 Gb service to the house and a xfinity xfi modem in bridge mode. My router is an orbi RBK50 with 2 satellites connected through ethernet for the backhaul. My workstation ...
- Mar 28, 2020
Thanks for the responses everyone! I tested the cables and the cable between the router and the switch was bad! All fixed and getting the same performance as the router on the ethernet!
Mar 28, 2020Guru - Experienced User
What are you speed results if you remove the switch between the RBR and PC?
Try testing with a different PC to compare results...
