TomMac's avatar
TomMac
Guru
Jun 23, 2019
Slow ethernet speed via Orbi Port
This has been driving me a bit crazy lately...
Setup;
Win10 computer / Orbi 50 Main ( and one Sat ) / Cable Modem Arris 1602 / cable speeds 120Mbs+ dwn & 35Mbs+ up
Running latest updates on Win 10 and fw 2.3.1.60 on Orbi main & Sat
Issue;
Slow speeds via ethernet port to Win 10 computer
Seeing  at computer only ( used several speed tests ) 27Mbs down and 35Mbs up.... using same cable direct to modem I see full speeds of 120M/35M ( download only seems effected )
Use to see full speeds at computer till about 10 days ago... during that time I upgraded to fw .60., no other changes that I know of.
( wifi on devices not effected and at full speeds )
Things tried;
Reset modem / full reset Orbi / downgraded FW back to .48 ( and no diff so went back to .60 ) / changed ports / changed cables / removed all other etherent cables but computer / Checked QoS setting ( not on , seeing full cable speeds in QoS speedtest ) / checked win 10 ethernet board setting ( at 1GB )
So it appears the computer is fine as direct to modem I get full speeds, wifi from Orbi is at full speed, only when via Orbi main ethernet port to computer is it slowed down...
Ideas ??
TIA Tom
  • All fiq out... Not Orbi it seems.
    tested by setting up second computer / win 10, with same ethernet cable and that gets full cable speeds thru port
    So something has changed in the main computer, now to fiq that out.
    ( but still odd that when direct to modem gives me full speed  on main comp )
    • FURRYe38's avatar
      Besure all background running apps on PC are disabled. Use Ooklaas speed test app vs a web browser. Web browsers can impact speed performance. The app is more direct and no advertisments.
