silfverrugg
Sep 28, 2018Tutor
Slow LAN output from Orbing RB50
I have 600Mbts (measured by ISV) into the Orbi and connect my iMAC directly to one of the 3 LAN ports on the backside of the orbit and only measure 240Mbts. This is very strange and cannot be be cor...
silfverrugg
Sep 28, 2018Tutor
I have the latest firmware - V2.1.4.16. I have a Technicolor TG799vac Xtream router with a bridged connection to the Orbi that generates about 600Mbts. Traffic Meter is off, Parental Control off. The only QoS I have takes to speed test. Does this help?
BR
Sep 28, 2018Guru - Experienced User
You might try doing a factory reset on the Orbi and set up from scratch. This time, don't enable QoS on the Orbi, run a wired test.
So the Modem is in bridge mode?
Does the modem have a DMZ?
- silfverruggSep 28, 2018Tutor
Yes port 4 (out of 4) of the TG799 is bridged via a DMZ function. Reason is that I did had an Apple Time Capusle and used NAT for access a Media Server. How do I deslected QoS? I cnat find anywhere in the GUI to do that.
- FURRYe38Sep 28, 2018Guru - Experienced User
There isn't a disable. The only way is to reset the Orbi and setup from scratch then this time, don't set up QoS on it. Run some tests.
So I should reset Orbi and do a manual set up (allowing me to deslected QoS?) and not let the Orbi configure automatically?
