silfverrugg
Sep 28, 2018Tutor
Slow LAN output from Orbing RB50
I have 600Mbts (measured by ISV) into the Orbi and connect my iMAC directly to one of the 3 LAN ports on the backside of the orbit and only measure 240Mbts. This is very strange and cannot be be cor...
Christian_R
Oct 01, 2018NETGEAR Employee Retired
Hi @silverrugg,
Please let us know if FURRYe38's suggestion of downgrading your FW changes anything.
~Christian
- silfverruggOct 01, 2018TutorHi, can you pls advise how I do the downgrade? Thanks
- FURRYe38Oct 01, 2018Guru - Experienced User
Just download the file from NG support site for your model Orbi. Just the router only.
I would disconnect ALL devices accept for 1 wired PC. Then using IE11 or FF, send the FW file using the routers web page.
After it applies, do a factory reset and then set up the router from scratch and configure it. Run a quick ethernet connected test with the PC to check speeds.
Thx will try on Thursday and let you know before replacing it
