silfverrugg
Sep 28, 2018Tutor
Slow LAN output from Orbing RB50
I have 600Mbts (measured by ISV) into the Orbi and connect my iMAC directly to one of the 3 LAN ports on the backside of the orbit and only measure 240Mbts. This is very strange and cannot be be cor...
randomousity
Oct 01, 2018Luminary
Are you plugged into the Orbi router, or one of the satellites? If it's a satellite, then it could be related to a placement issue because the backhaul connection between the router and satellite isn't strong enough to support your full throughput. If you're plugged into the router, then I don't know.
silfverrugg
Oct 01, 2018Tutor
The router :(
