silfverrugg
Sep 28, 2018Tutor
Slow LAN output from Orbing RB50
I have 600Mbts (measured by ISV) into the Orbi and connect my iMAC directly to one of the 3 LAN ports on the backside of the orbit and only measure 240Mbts. This is very strange and cannot be be cor...
Retired_Member
Oct 05, 2018
silfverrugg wrote:
..." come closer the 600Mbts I get from my fiber modem?
What does this mean? How did you make this measurement?
You might want to tell all your current setup (modem/router, etc.)
- silfverruggOct 06, 2018Tutor
I connect my iMAC via LAN directly to ISV router (bridged port) and get 600MBts. This router is connected to Orbi with LAN cable. From Orbi LAN bort I get about 250-280MBts, ie I loose >50%
- FURRYe38Oct 06, 2018Guru - Experienced User
Lets get ahold of NG support and ask for help and information. I believe the router needs to be RMAd.
