Danmc2504
Nov 02, 2019Tutor
Slow LAN speeds on Orbi RBK50
I have the Orbi RBK50 connected to a Spectrum modem. I am on a 200 Mbps plan. On my phone and tablet via wifi, I get 200+ Mbps. However, I get 65 Mbps on my lan connected Windows 10 PC with 1 gig adapter. Cables are cat5e. Would appreciate any suggestions. Thanks.
I was able to solve my PC issue by running a freeware utility named TCPOptimizer. I let it pick the optimum settings. Sorry, I don't know the exact settings that it changed but my PC is now downloading at the same speeds as the wifi. My PC went from 65Mpbs to 230Mbps. Thanks again for the assistance.
Have you tried more than 1 device for the speedtesting? I'd recommend trying a different lan device with gigabit.
What device are you using? model number?
You put gigabit adapter. Do you mean its a usb-gigabit adapter or what exactly are you using?
Have you tried different ports on the router in case one is bad?
The Win 10 PC is my only LAN connected device. I verified that the built-in LAN connector on this device is rated at 1 gig. I have tried connecting from multiple ports on the satellite and multiple ports on the main Orbi RBR50. Thanks
Right. Here's the issue.
If wifi on both router and satellite is pulling the full 200mbps it means that the wan-wifi interface is full speed. it also means that the backhaul is passing full speeds. I can see either the router or the satellite having bad ethernet connections but not both. This is why I'd recommend testing with another device. Also try a different cable.
What firmware are you on?
has it ever hit gigabit or 200mbps speed over lan connection?
Have you checked in your windows device manager to see if something has been changed on the ethernet connector settings?
what lan device are you using? how are you sure it can max out your gigabit speeds? have you tested it to hit gigabit speeds?
I have an older atom pc device that has a gigabit connection but can't get anywhere near full gigabit speeds. Just because its rated gigabit, doesn't mean the computer can hit that speed.
