Danmccune
Nov 11, 2020Tutor
Slow LAN/Fast WiFi on Orbi RBK33
I am getting about 50% of my availble bandwidth using the LAN port on my RBR40 Orbi Router. My internet is 1GB fiber. If I take the ethernet cable from the WAN port of the Router and plug it into m...
Nov 11, 2020Guru - Experienced User
Firmware on the router?
what ont/gateway is it connected to?
Make sure parental controls, traffic monitoring, and access control are disabled. If they were enabled, disable them and reboot the router. Then try.
harrycharlesop
Nov 12, 2020Aspirant
plemans wrote:Firmware on the router?
Make sure parental controls, traffic monitoring, and access control are disabled. bkexperience If they were enabled, disable them and reboot the router. Then try.
Thanks, that really helped.
- DanmccuneNov 13, 2020Tutor
I configured the ONT for passthru, and reset the Orbi Router, but I am still having the same problem.
- Mikey94025Nov 15, 2020Hero
Danmccune wrote:I configured the ONT for passthru, and reset the Orbi Router, but I am still having the same problem.
Hmmm, is the RBR40 not powerful enough to handle your full upstream speeds? You've already tried all the wired speed issue steps in the community FAQ: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944.
- DanmccuneNov 15, 2020Tutor
So, I resolved the issue, kind of. I'm using the router on the ONT, configured the Orbi in Access Point mode, and connected the ONT to the Orbi on a LAN port rather than the WAN (yellow) port. With this method, I can get ~800Mbps on my laptop with a wired connection.
The problem seems to be the WAN port. If I connect the ONT to the Orbi thru the WAN port, I get ~400Mbps. If I use the LAN port, I get ~800Mbps.
The only problem I have now is that the Orbi continues to flash purple.
