dan801
Jul 21, 2019Apprentice
Slow Max Wifi Speed or incorrect wifi setting?
My wifi settings seem to be in-correct or not properly configured. The maximum speed i'm able to achieve on the 5g frequency is only 866mhz and I thought this should be a lot higher? I also can't sel...
ekhalil
Jul 21, 2019Master
dan801 wrote:........ The maximum speed i'm able to achieve on the 5g frequency is only 866mhz ......
If you mean that you're getting 866 Mbps with wireless devices then you're really getting the maximum that you can get out of Orbi.
Please see attached table showing the possible bit rates in Orbi depending on the number of used spacial streams (no, dual or multiple MIMO), channel bandwidth (20, 40 or 80 MHz) and the radio conditions.
The maximum possible rate that you can get from Orbi is 866.7 if using dual MIMO, 80 MHz channels and with best radio conditions (MCS 9).
