JugalB
Feb 03, 2019Aspirant
Slow ORBI wired speeds
I have the orbi rbk22, the wireless internetspeeds work flawlessly, but when i try to connect my laptop to the orbi via ethernet, the speed is capped at 100mpbs when i look in network and sharing cen...
ekhalil
Feb 03, 2019Master
Does your ISP support IPv6? If yes do you have the correct IPv6 in the web GUI under >> ADVANCED >> Advanced Setup >> IPv6 ?
- JugalBFeb 03, 2019Aspirant
ShankarHokie ekhalil My isp is Rogers and yes it does supports ipv6 as well as my network card because ipv6 work and i get the full 500mbps when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop. And how do i disable daisy chain? And another piece of info which could be useful is that i connect the laptop to the main orbi not the satellite.
- FURRYe38Feb 03, 2019Guru - Experienced User
JugalB wrote:
Yes my isp supports ipv6 because i get it when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop.
- ShankarHokieFeb 03, 2019Apprentice
Hi.
