JugalB
Feb 03, 2019Aspirant
Slow ORBI wired speeds
I have the orbi rbk22, the wireless internetspeeds work flawlessly, but when i try to connect my laptop to the orbi via ethernet, the speed is capped at 100mpbs when i look in network and sharing cen...
ekhalil
Feb 03, 2019Master
Does your ISP support IPv6? If yes do you have the correct IPv6 in the web GUI under >> ADVANCED >> Advanced Setup >> IPv6 ?
JugalB
ShankarHokie ekhalil My isp is Rogers and yes it does supports ipv6 as well as my network card because ipv6 work and i get the full 500mbps when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop. And how do i disable daisy chain? And another piece of info which could be useful is that i connect the laptop to the main orbi not the satellite.
- FURRYe38Feb 03, 2019Guru - Experienced User
JugalB wrote:
Yes my isp supports ipv6 because i get it when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop.
Look at the modem device that the Orbi is connected too. This modem box should have a stick and branding on it.
Unless you connect the Orbi router to a wall out let then, don't worry about finding the Mfr and model.
JugalB wrote:
FURRYe38 where do i get those 2 pieces of information?
- ShankarHokieFeb 03, 2019Apprentice
Hi.
- JugalBFeb 03, 2019Aspirant
ShankarHokie i am unable to view you latest 2 responces. Here is what it look like from my end: http://prntscr.com/mg6zhz
