JugalB
Feb 03, 2019Aspirant
Slow ORBI wired speeds
I have the orbi rbk22, the wireless internetspeeds work flawlessly, but when i try to connect my laptop to the orbi via ethernet, the speed is capped at 100mpbs when i look in network and sharing cen...
JugalB
ShankarHokie ekhalil My isp is Rogers and yes it does supports ipv6 as well as my network card because ipv6 work and i get the full 500mbps when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop. And how do i disable daisy chain? And another piece of info which could be useful is that i connect the laptop to the main orbi not the satellite.
Feb 03, 2019Guru - Experienced User
JugalB wrote:
Yes my isp supports ipv6 because i get it when i connect to my isp modem. I went on to the web GUI and put IPV6 to auto config but it still says ipv6 no internet connnectivity on my laptop.
- FURRYe38Feb 03, 2019Guru - Experienced User
Look at the modem device that the Orbi is connected too. This modem box should have a stick and branding on it.
Unless you connect the Orbi router to a wall out let then, don't worry about finding the Mfr and model.
JugalB wrote:
FURRYe38 where do i get those 2 pieces of information?
- FURRYe38Feb 07, 2019Guru - Experienced User
Any progress on this?
