JugalB
Feb 03, 2019Aspirant
Slow ORBI wired speeds
I have the orbi rbk22, the wireless internetspeeds work flawlessly, but when i try to connect my laptop to the orbi via ethernet, the speed is capped at 100mpbs when i look in network and sharing cen...
ShankarHokie
Feb 03, 2019Apprentice
- Who is your ISP? Do they support IPV6?
- IPV6 should not matter for speeds. I get the full speed on my desktop via ethernet and IPv4
- Have you checked if your network card is capable of 1Gbps? Most old cards are only 10/100
- I had similar slow LAN speed and I disabled the daisy chain topology and I got full speed
- On the router Advanced => Advanced Setup => IPv6, choose internet connection type as DHCP, IPv6 DNS as automatically get from ISP, and LAN stup as autocnfig
- Then test at https://test-ipv6.com/ to see if you get 10/10
JugalB
ShankarHokie when i ran the test-ipv6 it came with a result saying "no ipv6 address detected", but it work when i plug it into my isp modem.
