Aleburd
Apr 04, 2019Aspirant
Slow Ping on Wired Backhaul?
I've been using the Orbi for 6 months now and have them upgraded to the latest firmware V2.3.1.44. In my home I have it pre-wired with CAT5e cable to every room. I've set up the Orbi Router in my m...
Apr 04, 2019Guru - Experienced User
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Has a factory reset and setup from scratch been performed since updating to v44?
What Rev # is the 1024D switch? A, D G or H?
Can you bypass the switch and connect one or both satellites directly to the back of the RBR?
