Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Codybuts
Sep 09, 2019Aspirant
I haven't done a factory reset since before this new modem, tech had me setup dynamic IP to see if it solved the issue but it ended up being the modem.
Router and sat 1 speeds are fine it's just sat 2.
Would this be something I should try
