Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Sep 10, 2019Guru - Experienced User
What is the distance between Sat 1 and Sat 2?
Daisy Chain enabled?
What happens if you turn OFF both RBS, swap Sat 1 and Sat 2 locations?
Is the transmit power on the RBR set for 100%?
Codybuts
Sep 10, 2019Aspirant
Distance between sat 1 and 2 is prob 39 ft with brick wall in way ( sat 1 in window basement facing garage where sat 2 is )
And it seemed moving sat 2 closer to say 1 gave even worse speeds . It's now farthest in garage just always goes back to 2.4
Daisy chain enabled , fast enabled, 20/40 unticked, mimo enabled beamforcing enabled.
Transmit power is 25 on 2.4 and 100 on 5.
Have tried swapping
Have tried swapping
- FURRYe38Sep 10, 2019Guru - Experienced User
Set transmit to 100% on RBR.
Possible that this brick wall will be a factor.
